TCP/IP问题求救!TCP/IP问题求救!
TCP/IP问题求救!
准备作2003无盘终端,听说只支持TCP/IP-VSL,我因而准备了如下
AUTOEXEC。BAT文件:
@ECHO OFF
SET COMSPEC=C:\DOS\COMMAND.COM
SET PATH=C:\LANMAN.DOS\NETPROG;C:\DOS;C:\BINR;C:\BINB;
SET PROMPT=$P$G
SET TMP=C:\TMP
SET TEMP=C:\TMP
SET DOSSHELL=C:\WKSTA
rem VER
@ECHO ON
C:\LANMAN.DOS\DRIVERS\PROTOCOL\TCPIP\UMB.COM
NET START RDR /RPL:YES /FIT:YES /COMPUTERNAME:(COMPUTER_NAME) /HIMEM:YES
@FIXMEM
LOAD TCPIP
C:\LANMAN.DOS\DRIVERS\PROTOCOL\TCPIP\NMTSR.EXE
LH SOCKETS
lh vsl
CONFIG。SYS文件:
DEVICE=C:\BINR\RPLLNK.SYS
SHELL=C:\DOS\COMMAND.COM C:\DOS /P
LASTDRIVE=Z
BUFFERS=10
FILES=30
STACKS=9,256
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM NOEMS X=9380-9FFF
DOS=HIGH,UMB
DEVICE=C:\LANMAN.DOS\DRIVERS\PROTOCOL\TCPIP\NEMM.DOS
DEVICE=C:\dos\SMARTDRV.EXE /DOUBLE_BUFFER
DEVICE=C:\IFSHLP.SYS
可是在启动 DOS 时,却提示“Could not find TCP/IP support”,向各位大侠请教。
