我在做PXE时遇到一些问题希望各位大哥帮帮我.
具体是这样的,PXE可以启动到DOS,NET START IPX 也正常,在NET START WORKSTATION 出现
Error 7361: IPX or NETBIOS must be running in order to load the network
services your computer may be configured to use a monolithic driver such
as IPX or XNS, and the driver is not loaded . to load the driver,follow
the instructions in the documentation that comes with your secondary network.
在启动到98时也出现这样的提示,到底这样解决呢,望请各位帮帮小弟,感激不尽.
我没遇到过,所以你最好是重做
