请高手救命啊,给大虾们鞠躬了!
3台瘟98同时启动,随机的出现选卡不能驱动的问题,但先启动的机子绝对没的问题。另外只有一台机子可以正常使用,另2台奇慢无比,跟死机差不多。这是什么原因,请高手指点。k6-2-400,64m,SIS530,1816.
可以试试将CPU降频使用!!!!K6CPU好象在无盘下工作不是很稳定。
速度慢肯定有一点,但不知道你慢的程度??
这明显是虚拟内存的设置问题,和cpu无关。
是慢的不能接受!虚拟内存怎么设置?设多大好一点!另外我发现在USERCMD。BAT中去掉QVMEM S: %SERVER% %USERNAME%就可以接受速度了。但 很容易报错!!!请救命!先谢了!
[被 萌萌 编辑过(日期 12-23-2000)]
把你的机器和网络备置写出来看看, 也许你还要检查你的网线连接是否正确。
SIS530,64MHY,K6-2-400,1816,RTL8139C。网线不是我做的,但有盘站对考文件速度可以!只开一台是没任何问题的1
兄弟,你的问题很好办,和cpu没关系,我安装了30台pxe无盘win98,k6-450,华基sis530,64m内存,配置一样吧,虽然某些问题还有待解决.修改usercmd.bat文件:
PATH %PATH%;C:\LITENET
rem Put QNetName.exe in your path and uncomment ‘rem QNetName.exe’
rem and ‘rem call QNBName.bat’ if you want to use DHCP system on multiple clients.
rem Please read the associated documentation to know how to use QNetName
QNetName.exe
call %TEMP%\QNBName.bat
rem Please read the associated documentation to know how to use QUserMan
QUserMan %HOME%
rem Put QSetBD.exe in your path and uncomment ‘rem QSetBD.exe’
rem if you want to make the system think it booted from disk %DRIVE%.
rem Please read the associated documentation to know how to use QSetBD
QSetBD %DRIVE%
rem the next line will perform auto logon feature if TweakUI is installed
rem in windows system folder and if QAUTOLOG created A:\WINBOOT\QAUTOLOG.REG file
if exist %WINDIR%\SYSTEM\TweakUI.CPL if exist a:\winboot\qautolog.reg regedit a:\winboot\qautolog.reg
rem Put QRestAll.exe in your path and uncomment the next line
rem if you want to use floppy drive and IDE devices with intel dosundi
if exist %HOME%\patched.reg goto notchange
qpatch c:\windows\chn.reg %HOME%\patched.reg
regedit %HOME%\patched.reg
:notchange
Qvmem s: %server% %username%
QRestAll
choice /C:YN /T:Y,03 Hit N and Ctrl-C not to launch Windows (stop the batch)
if errorlevel 2 pause
%windir%\win.com
在 SYSTEM.INI文件的[386Enh]栏中增加3行:
PagingDrive=S:
MinPagingFileSize=65536
MaxPagingFileSize=65536 (适当修改加大)
这样可以生成s:盘,并在此盘中生成win386.swp文件.
谢谢各位了。现在我5台瘟98基本正常使用!装了OFFICE2000,超级结巴2000,连种游戏。中国在先游戏。OICQ0820,还有几个股票分析软件等等!现在在想权限的问题。请各位指教!
萌萌,你使用的litenet是哪下载的什么文件名(old.zip,new.zip,litenet1.zip,litenet2.zip),同时启动是否偶尔有丢失字符的现象("开始"菜单,桌面图标的中文字符)?
