网卡RPL引导时间调整参考
给个程序,是原厂的,可以参考一下。
哦,怎么啦,不能上传附件了?
贴段CFG的内容,希望有用。
NodeID = 00 10 DC 77 11 98 ; Note: Leave at least one blank space between
VID = 10 EC ;Vendor ID
DID = 81 39 ;Device ID
MNGNT=20 ;Minimum Grant Timer
MXLAT=40 ;Maximum Latency Timer
SVID= 10 EC ;Subsystem Vendor ID
SMID = 81 39 ;Subsystem ID
BOOTROM = ENABLE ;Boot ROM Size
DRVLOAD = NOTUSED ;Driver Load
LEDS0 = NOTUSED ;LED pin
LEDS1 = USED ;LED pin
FUDUP = USED ;Duplex mode
ANE = USED ;Auto Negotiation
SPD = NOTUSED ;Network Speed
RXFCE = NOTUSED ;RX Flow Control
TXFCE = NOTUSED ;TX Flow Control
GNTSel = USED ;Gnt Select
PARM_En = USED ;Twister parameter
Magic = USED ;Magic packet receive
LinkUp = NOTUSED ;Link Change Wake Up
FBtBEn = USED ;Fast Back to Back
PMEN = USED ;Power Management Enable (PME#)
PMCX=c2 f7 ;power management capabilities
PMCSR=01 ;power management control/status
PHY1_PARM=B9 03 F4 60 ;PHY parameter 1
PHY2_PARM=1A ;PHY parameter 2
TW1_PARM=A3 DF 36 98 ;Twister parameter 1
TW2_PARM=A3 DF 36 98 ;Twister parameter 2
TW3_PARM=B9 03 F4 60 ;Twister parameter 3
TW4_PARM=1A 1A 1A 1A ;Twister parameter 4
AnaOff=NOTUSED ;Analog Power Off
LongWF=NOTUSED ;Long Wake-up Frame
LWPME=NOTUSED ;LANWAKE vs PMEB
LWACT=NOTUSED ;LWAKE active mode
LWPTN=NOTUSED ;LWAKE pattern
MSWFB=USED ;Wake-up Frame
;E_PARM_En2=USED ;Parameter Enable2
E_PARM_En2=NOTUSED
;VPD= USED ;Set to enable Vital Product Data
VPD=NOTUSED
;CardB_En=USED ;Card Bus Enable
CardB_En=NOTUSED
CLKRUN_En=USED ;CLKRUN Rnable
;CLKRUN_En=NOTUSED
;FuncReg_En=USED ;CardBus function register enable
FuncReg_En=NOTUSED
RxFIFOAutoClr=USED ;clear Rx FIFO overflow automatically
;RxFIFOAutoClr=NOTUSED
DisNwayFlowControl=USED ;Disable Nway flow control
;DisNwayFlowControl=NOTUSED
;LDPS=NOTUSED ;Link Down Power Saving
LDPS=USED
;LANWake=NOTUSED ;LANWake signal
LANWake=USED
;PME_STS=NOTUSED ;PME_Status
PME_STS=USED
PBWakeup=NOTUSED ;Pre boot wakeup
;PBWakeup=USED
; PG8139 : to program 9346/9356 for RTL8139X
; * RTL8139X use different .cfg file to write 9346/9356
; RTL8139 - 8139.cfg
; RTL8139A - 8139A.cfg
; RTL8139B - 8139B.cfg for PCI
; RTL8139B - 8139CB.cfg for Card Bus
; RTL8139C - 8139C.cfg for PCI
; RTL8139C - 8139CCB.cfg for Card Bus
; RTL8130 - 8130.cfg
; * Only RTL8139B Command Line Support : pg8139 /pci (for PCI)
; : pg8139 /cb (for Card Bus)
; * There must be only one RTL8139B card on the PC.
; * The RTL8139B will conflict with the FDD if a blank 9346/9356 is used.
; Thus, HDD is recommended to program a blank 9346/9356.
; * The NodeID in 8139B.CFG file will be incremented by
; one after 9346/9356 programmed.
;BOOTROM = 8K ;Boot ROM Size
;BOOTROM = 16K ;Boot ROM Size
;BOOTROM = 32K ;Boot ROM Size
;BOOTROM = 64K ;Boot ROM Size
;BOOTROM = 128K ;Boot ROM Size
;E_VPDDATA= ;VPD data
ROMconfig=20
;Bit 7-6 Boot Protocol
; 00 ==> PXE protocol
; 01 ==> RPL protocol
                    ;Bit 5-4    Boot order (method)
                    ;           00 ==> ROM disable
                    ;           01 ==> Int 18h
                    ;           10 ==> Int 19h
                    ;           11 ==> PnP/BEV(BBS)
                    ;Bit 3      Show Config Message
                    ;           0 ==> Enable
                    ;           1 ==> Disable
                    ;Bit 2      Reserved
                    ;Bit 1-0    Show Config Time
                    ;           00 ==> 3 Seconds
                    ;           01 ==> 5 Seconds
                    ;           10 ==> 8 Seconds
                    ;           11 ==> 0 Seconds
看不懂!
同楼上
就是pg8139的配置文件。39d.cfg
很多人从网上弄来的PG8139都缺这个文件,有完整的文件就可以“生产”网卡了。
