我换了一个CPU之后,就老是出现这样的情况,莫名其妙的出现以下的文字,希望高手们不吝赐教。现将文字抄录如下:
A problem has been detected and windows has been shut dowm to prevent damage to yous computer .
If this is the first time you have seen this stop error screen, restart your computer.If this screen appears again, follow these steps :
check to be sure you have adequate disk space .iF a drive is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters .
check with you hardware vendor for any BIOS updates .Disable BIOS memory options such as cathing or shadowing. If you meed to use Safe Mode to remove or disable components ,restart your computers, press F8 to salect advanced startup options ,and then select Safe Mode .
Techmical imfoumation:
*** STOP :0 X 0000008E (0 X C0000005 ,0 X 00000000 ,0 X F82BFAFO ,0 X 00000000)
Beginning dump of physical memory .
Physical memory dump complete .
Contact your system group for further assistance .
成分感谢!!!
