我要拜师
nt4+张的rpl98
服务器和工作站配置好后,打开工作站,工作站在显示完win95画面后,就发出声音并提示:“Please run SETWIN98 on w98server !”
我把前面的启动信息抄了一下:
D:/WINBOOT>NET Logon USER01 /YES, /sowepw:no >kb
PRO 0003E:PROTOCOL.INI file open failure
Error loading device driver PROMAN.DOS
Error 7361: IPX or NETBIOS must be running in order to oad the network
services,
Your computer may be configured to use a monolithic drive is not
loaded. TO loaded the driver,follow the instructions in the documentation that comes with your secondary networ.
D:\WINBOOT\net use c:\w98server\win98
The WORKSTATION service is not started,Is it ok to start it?(y/n)[y]
这是我安提示输入y,这时候就发出声音并提示:“Please run SETWIN98 on w98server !”
张的帮助文件中说c盘没映射成功,凤凰老师说是网卡驱动没有装,请问这到底是怎么一回事?如果说是网卡驱动没有装,该怎样装?怎样让c盘映射成功?
w haoxiang yijing gaosu ni l ,zhishi ni de lijie budui eryi !
w jiu shi ni na ge ben xuesheng,bu yao guai wo bu zhengqi.主要是因为事了很多次都不能成功,心里很着急。能否讲的详细一些?
Most simple method , oneself to go I download and all have dishes of materials is after you have finished thinking, Not only can solve your problem , but also your engineering level will be improved and cut greatly
凤の凰 你在说什么啊?,他的问题是SUBOOT目录下的最小注册表不对啊!
不是吧?我记得我以前遇到这个问题时,把网卡驱动装上就好了……
