大家看这是东西能干什么,CITRIX的网页上的.
Citrix® Secure Gateway
Product Highlights
Resources
Leverage the Internet.
Citrix® Secure Gateway allows Citrix MetaFrame® for Windows® and Citrix MetaFrame 1.1 for UNIX® customers to simply and securely deliver business-critical applications over the Internet, on demand to any device. Citrix Secure Gateway protects remote users of Citrix Independent Computing Architecture (ICA®) across the Internet by functioning as a Secure Sockets Layer (SSL) gateway between Citrix MetaFrame servers and Citrix ICA client devices. It also provides a single point of entry and secure access to Citrix MetaFrame server farms.
Secure data transfer.
Citrix Secure Gateway is an enterprise-wide solution that protects a customer’s network infrastructure, data and applications. All Citrix ICA traffic traversing the Internet between client devices and the Citrix Secure Gateway server is encrypted using Internet-standard SSL technology, ensuring the secure transfer of data across public networks.
Easy deployment.
Citrix Secure Gateway eliminates the need to install additional client software (beyond the Citrix ICA client) and can easily traverse Internet firewalls. It is completely transparent to both applications and network devices.
Simple to use.
Citrix Secure Gateway removes the need to publish the address of every Citrix MetaFrame server across the Internet. It simplifies server certificate management and provides a single point of access into the Citrix MetaFrame server farm. Citrix MetaFrame servers are hidden from the Internet and cannot be accessed directly.
什么玩意?安全网关?这有什么用啊?
意思好象是利用它能通过INTERNET连接远程终端,如果真是如此倒是很有用处的哟!
通过INTERNET连接远程终端我们早就做出来了啊
是吗?可不是远程桌面共享哟,也是用MF1.8做的吗?怎么做的可以说说吗?
用微软自己的终端高级客户端程序或者是MFXP都可以实现远程终端登陆!
