哪里有lindows下载???
www.lindows.com有,不过要10$,如果你有了不要忘记给大家Share出来啊!
可惜我没有美元。。。。
何不试试国产的LINDOWS
ftp://202.118.72.12/incoming/Linux/Lindows.zip
#This is xteamlinux for windows 0.9 readme file.
#Copyright 1999 XteamSoft under the GPL license.
#Copyright 1999 MandrakeSoft under the GPL license.
#Authors : Alexandre Dussart & Warren Downs.
#Please report all bugs at dn@xteamlinux.com.cn
Lnx4Win allows you to install Linux directly on a windows partition without
fdisk and it is still true Ext2 file system.
Installation of Lnx4Win
I - Requirements:
- Hardware system compatible with Linux Xteamlinux.
- 64Mb RAM
- 500 Mb free space on Windows partition.
- Windows™ 95/98
SCSI only systems can’t install Lnx4Win.
II - Start
Please follow these steps carefully :
- Run scandisk to clean up your system.
- Run setup.exe from lnx4win installed directory.
- Select the linux system drive.
- Select the linux swap size.
- Press Ok to begin the system under Linux.
III - Installation of the system
- Wait until the format and setup image is done.
- The installation procedure is the same as standard installation but without
all partitionment and bootloader installation steps. - When you select package you must let 5Mb free to correctly install the kernel.
- When the installation is finished, you can reboot under Windows.
IV - Desinstallation of the system
- Run uninstall.bat script.
- Remove latest files manually.
- Run scandisk program.
This is End .
Snow Wolf Di dn@xteamlinux.com.cn
Dec 3 ,1999
另外ftp://202.118.72.12/incoming/Linux/WL2000.EXE好象是Winlinux,也可在WINDOWS下安装。
