cisco 6509—港湾uharmmer24E
两台机器互联:cisco 6509—港湾uharmmer24E(支持802.1q)
现状是:
cisco 6509通过port3/47 (on dot1q trunking)与港湾24E的port1(on tagging)相连。
港湾24E可以学习到6509里面的vlan,并分配到该机器的不同端口上,下连的电脑可以正常获得IP上网。
问题是:
cisco 6509—港湾uharmmer24E 相互PING不通。
无法远程TELNET上去管理,郁闷ing・##・%!!
请大家帮忙看看哦,感谢!
cisco 6509的port3/47
auts6509 (enable) sho port 3/47
Port Name Status Vlan Duplex Speed Type
3/47 connected trunk a-full a-100 10/100BaseTX
Port AuxiliaryVlan AuxVlan-Status InlinePowered PowerAllocated
Admin Oper Detected mWatt mA @42V
3/47 none none - - - - -
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
3/47 disabled shutdown 0 0 1 disabled 76
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
3/47 0 - - - - -
Port Broadcast-Limit Broadcast-Drop
3/47 - 0
Port Send FlowControl Receive FlowControl RxPause TxPause Unsupported
admin oper admin oper opcodes
3/47 off off off off 0 0 0
Port Status Channel Admin Ch
Mode Group Id
3/47 connected auto silent 875 0
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
3/47 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
3/47 0 0 0 0 0 0 -
Port Last-Time-Cleared
3/47 Tue May 10 2005, 21:53:28
Harbour(config)# sho port 1
Port:1 's Configuration Information
Link state : Up Port state : Enabled
AutoNegotiation : Enabled Speed : 100BaseTX
Duplex : Full FlowControl : Disabled
