云峰的注册方法,我用翻译软件翻译了一下,
How to overcome 90-day’s restriction on use Windows 2000 AS Terminal Service?
Some ways:
To remove on CLIENT’s machine in the system register key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSLicensing\Store And enjoy feeling of self-satisfaction from the carried out certificate(act) of violation Above license politics MS. (unfortunately will be reached to repeat everyone 90 days..)
At activation to choose Web-registration (not Internet registration), further https://activate.microsoft.com, To enter number established Windows and to receive a code.
BEFORE install W2k TS to replace system date on some years forward, and after - to restore.
Use for SERVER:
=====8<===W2kTS.Crk from $CRACK$=======
NT 5.02 B-2195 [TerminalServer] (C) by HW
Remove expiration and limit checks! (RA mode) ICAAPI.DLL
00004B84: 17 00 ; Connections licensed
00004CC7: 7C EB ; Connections allowed
00004DAA: 74 EB ; Expirationless
=====8<===============================
After these manipulations Windows wants to return all as was (is at it useful in all except for this case peculiarity - protection of system files) Therefore DLL it is necessary to correct not only in %SystemRoot %\system32\ but also in %SystemRoot %\system32\dllcache - Otherwise file will be replaced by system on old, taken therefrom… Well and on the requirement to thrust CD with Windows Setup, it, naturally, too It is necessary fuck it…))..
It is necessary to go on https://activate.microsoft.com to fill in the questionnaire anyone bla-bla (But! Entered a Name, Surname, Organization should in accuracy further be entered In properties SERVER), in a result you receive a code for activization server of the licenses (That after 90 days at you still worked server of the licenses), further to you will be It is offered to register your licenses - fill in necessary quantity(amount) And most interesting moment! At you will request number of the application (Enrollment Agreement Number), in anyone search machine type: " Enrollment Agreement Number " Also receive number - a code of a key package of the licenses! Is Also THERE IS a GENERATOR of the LICENSES KINDLY GIVEN MICROSOFT!!
For the beginning Enrollment Agreement Number 6565792; 5296992… The note.
That all has passed successfully, you need to know:
25-digit serial number (five times till five symbol(digit/letter) of Windows 2000 server on the basis of which generating of a product xxxxx-xxx-xxxxxxx-xxxxx;
On the basis of a code of a product generating 35-digit/letter a code server of the licenses (seven time till five symbol(digit/letter);
On the basis of a code server of the licenses, Surname, Name, Organization and 7-symbol Enrollment Agreement Number generating 35-symbol(digit/letter) a code of a key package the licenses (seven times till five symbol(digit/letter)). Therefore, if this chain does not belong to one server, will not work most likely…
怎么作为终端服务在使用 Windows 2000 上克服 90-day’s 限制?
一些方法:
在系统在顾客的机器上搬迁登记关键的 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSLicensing\Store 并且乐
于自满感到从执行了证书 ( 行为)在许可证政治 MS 上面的违背 ( 将不幸地被到达重复每个人 90 天……)
在选择网登记的激活 ( 不因特网登记 ), 推进 https://activate.microsoft.com , 进入建立的数字 Windows
并且收到代码。
以前安装 W2k TS 代替系统在一些年的日期向前,并且在以后 - 恢复。
为服务者的使用:
新台币 5.02 B-2195 终端服务者 由 * HW *
移开终止并且限制检查!( RA 模式 ) ICAAPI.DLL
00004B84 :17 00 ;连接准许了
00004CC7 :7C EB ;连接允许了
00004DAA :74 EB ;终止少些
在这些以后操作 Windows 想要都返回哪个是 ( 在它有用在除了这诉讼的所有怪癖 - 系统文件的保护 ) 因此动
态链接库改正,是必要的不仅在 % 系统根 %\system32\ 而且在 % 系统根 % \system32\dllcache - 否则文件
将被系统代替在上旧, 拿由此而来…很好并且在与 Windows 安装插入 CD 的要求上, 它, 自然地, 也它是必要
的淫它…)) ……
继续 https://activate.microsoft.com 填问询表任何人 bla-bla ,是必要的 ( 但是!进入了一个名字, 姓,
组织应该进一步在性质服务器在精确性被进入 ), 在结果你为许可证的 activization 服务器收到代码 ( 那仍
然在在你的 90 天以后工作了许可证的服务器 ) ,将进一步到你它被提出登记你的许可证 - 填必要的数量 (
数量 ) 并且最有趣的片刻!在你请求将应用程序数字 ( 注册协议数字 ), 在任何人搜索机器类型:“注册协议
数字”也收到数字 - 许可证的一个关键的包裹的代码!也是有好心被给定微软的许可证的一个生成器!!
为开始注册协议数字 6565792 ;5296992…笔记。
那所有成功地过去了, 你需要知道:
25 位序列号 ( 乘到 5 为止的 5 标志 ( 位 / 信 ) 在的基础上的 Windows 2000 服务器一个产品产生
xxxxx-xxx-xxxxxxx-xxxxx ;
在一个产品的代码的基础上产生 35-digit/letter 许可证的一个代码服务器 ( 7 预定标志到 5 为止 ( 位 /
信 );
在许可证,姓,名字,组织和 7 标志注册协议的一个代码服务器的基础上数字产生 35 标志 ( 位 / 信 ) 一个
关键的包裹的代码许可证 ( 7 预定标志到 5 为止 ( 位 / 信 )) 。因此, 如果这链不属于一个服务器,将不很
可能工作…
不是说得明明白白的吗?而且已经能注册了。
非常感谢云峰大哥。
哈哈哈!!!不翻译还好,翻译软件太烂了!
不过,真是万分感谢!
