我的路由器是CISCO2610,有双ETHERNET接口,有一ADSL MODEM专线(有固定IP号)。现在已配置好局域网通过ADSL共享上网,可我要配置VPN(远程用户通过拔号VPN进入到我的局域网),我应该怎样配置我的路由器(IOS)?
望多多请教。 谢谢。
我告诉你
Cisco 2600 with GRE Tunnel
Current configuration
version 12.0
sevice timestamps debug uptime
sevice timestamps log uptime
sevice password-encryption
hostname bluestudy1
enable passsword cisco
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
interface Tunnel0
ip address 172.16.101.1 255.255.255.0
no ip directed-broadcast
ip mtu 1467
tunnel sourece 199.1.1.2
tunnel destination 199.1.2.2
interface serial0/0
no ip address
encapsulation frame-relay
no ip mroute-cache
frame-relay lmi-type ansi
interface serial0/0.1 point-to-point
description connected to internet
ip address 199.1.1.2 255.255.255.248
ip nat outside
no arp frame-relay
frame-relay interface-dlci 111
interface ethernet0/0
ip address 172.16.1.1 255.255.255.0
ip nat inside
router eigrp 100
network 172.16.0.0
router rip
version 2
network 172.16.0.0
no auto-summary
ip nat pool bluestudy 199.1.1.3 199.1.1.10 netmask 255.255.255.248
ip nat inside sourece list 2 pool bluestudy overload
ip nat inside sourece static 172.16.1.3 199.1.1.5
ip classless
ip route 0.0.0.0 0.0.0.0 srial0/0.1
ip http server
access-list 2 permit 172.16.1.0 0.0.0.255
snmp-server community public RO
line con 0
exec-timeout 0 0
password cisco
login
transport input none
line aux 0
line vty 0 4
password cisco
login
end
Cisco 2600 Configuration with IPSec
version 12.0
hostname bluestudy1
ip subnet-zero
no ip domain-lookup
crypto isakmp key policy 1
authentication pre-share
group 2
crypto isakmp key slurpee-machine address 172.16.101.2
crypto ipsec transform-set test ah-sha-hmac esp-des esp-sha-hmac
set transform-set test
crypto map bluestudy 10 ipsec-isakmp
set peer 172.16.101.2
match address 101
interface Tunnel0
ip mtu 1467
interface serial0/0
no ip address
no ip mroute-cache
ip nat outside
no arp frame-relay
ip nat inside
router eigrp 100
network 172.16.0.0
router rip
version 2
network 172.16.0.0
no auto-summary
ip classless
ip http server
access-list 101 permit ip 172.16.1.0 0.0.0.255 172.16.2.0 0.0.0.255(对方网络,只有到这个网络的信息包才加密)
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
