netpc3.0 RPL版贴图
win2000服务器,rtl8029网卡,TNT2 Vanta显卡.
autoexec.bat
@ECHO OFF
if not exist D:\winboot\nul mkdir D:\winboot
copy c:\ D:\ >NUL
copy c:\winboot*.* D:\winboot >NUL
d: >NUL
cd \ >NUL
CALL win.bat >NUL
config.sys
device=C:\HIMEM.SYS /V
device=C:\ifshlp.sys
shell=C:\command.com C:\ /p
dos=high,umb
lastdrive=z
devicehigh=C:\ramdrive.sys 1380 /E
win.bat
@echo off
cls
mjset >NUL
set comspec=d:\command.com >NUL
nwrpltrm >NUL
REM fixmem >NUL
SUBST A: D:\ >NUL
set comspec=A:\command.com >NUL
a: >NUL
cd \winboot >NUL
call SETENV.bat >NUL
CALL WU.bat >NUL
setenv.bat
@ECHO OFF
SET USN=%USERNAME%
REM SET USN=HJ
SET SRV=WU
SET LOG=PWIN97
SET CLR=2
rem SET ADMSH=ADMSH
REM SET CIP=%USERIP%
SET CIP=0.0.0.0
SET MSK=0.0.0.0
rem SIP=“DefaultGateway”
SET SIP=192.168.0.100
wu.bat
@ECHO OFF
CLS
;空两行,想一想
;对照原批处理,适当修改
SET WINDIR=C:\WINDOWS
SET SYSDIR=%WINDIR%\SYSTEM
A:
CD\WINBOOT
SET TEMP=A:\WINBOOT
SNAPSHOT /S /r /v /B:A /M:124
NET START IPX /Y
NET LOGON %USN% /SAVEPW:NO /Y < pw
NET USE C: \%SRV%%LOG% /Y
NET TIME \%SRV% /SET /YES
SET HOMEDIR=D:
IF %CLR%==2 SET HOMEDIR=C:
SET PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
IF NOT %CLR%==2 NET USE %HOMEDIR% \%SRV%%USN% /Y
SET TEMP=%HOMEDIR%
SET TMP=%TEMP%
SET HOME=%TMP%
SET REGDIR=%HOME%
%HOME%
SET COMSPEC=C:\WINDOWS\COMMAND.COM
IF %CLR%==0 GOTO Lab1
IF %CLR%==2 GOTO Lab2
IF %CLR%==1 GOTO Lab3
:Lab1
IF EXIST %HOME%\SYSTEM.DAT A:\WINBOOT\ATTRIB -H -S -R %HOME%\SYSTEM.DAT >NUL
IF EXIST %HOME%\USER.DAT A:\WINBOOT\ATTRIB -H -S -R %HOME%\USER.DAT >NUL
CLS
IF NOT EXIST %HOME%\SYSTEM.DAT A:\WINBOOT\COPYER C:\SYSTEM.DAT %HOME%\SYSTEM.DAT >NUL
IF NOT EXIST %HOME%\USER.DAT A:\WINBOOT\COPYER C:\USER.DAT %HOME%\USER.DAT >NUL
IF NOT EXIST %HOME%\SYSTEM.DAT A:\WINBOOT\COPYER C:\WINDOWS\SYSTEM.DAT %HOME%\SYSTEM.DAT >NUL
IF NOT EXIST %HOME%\USER.DAT A:\WINBOOT\COPYER C:\WINDOWS\USER.DAT %HOME%\USER.DAT >NUL
:Lab2
CLS
GOTO Lab4
:Lab3
CLS
IF EXIST %HOME%\SYSTEM.DAT DEL %HOME%\SYSTEM.DAT >NUL
IF EXIST %HOME%\USER.DAT DEL %HOME%\USER.DAT >NUL
CLS
:Lab4
setmdir /M /R:%HOME% >NUL
if not exist %HOME%\temp\nul md %HOME%\temp > NUL
set temp=%HOME%\temp
set tmp=%HOME%\temp
set comspec=C:\command.com
set winbootdir=C:\WINDOWS
CLS
REM =======================================
REM 以下是注册表设定
SET HJREG=A:\WINBOOT\HJSRV.REG
ECHO REGEDIT4 >%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\TCPIP] >>%HJREG%
ECHO “StaticVxD”=“vtdi.386,vip.386,vtcp.386,vdhcp.386,vnbt.386” >>%HJREG%
ECHO “Start”=hex:00 >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\VXDSHOT] >>%HJREG%
ECHO “StaticVxD”=“VXDshot.vxd” >>%HJREG%
ECHO “NetClean”=hex:01 >>%HJREG%
ECHO. >>%HJREG%
ECHO [HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0000] >>%HJREG%
ECHO “DevLoader”=“*ndis” >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Network] >>%HJREG%
ECHO “DisablePwdCaching”=dword:00000001 >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer] >>%HJREG%
ECHO “LinkResolveIgnoreLinkInfo”=dword:00000001 >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer] >>%HJREG%
ECHO. >> %HJREG%
IF NOT %CLR%==1 GOTO SKIP_PNP
ECHO [HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\CONFIGMG] >>%HJREG%
ECHO “SYSDMFunc”=“WinMain” >>%HJREG%
ECHO. >> %HJREG%
:SKIP_PNP
ECHO [HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\TimeZoneInformation] >>%HJREG%
ECHO “DisableAutoDaylightTimeSet”=dword:00000001 >>%HJREG%
ECHO “Bias”=hex:00,00,00,00 >>%HJREG%
ECHO “StandardBias”=hex:00,00,00,00 >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders] >>%HJREG%
ECHO “Desktop”=“C:\WINDOWS\Desktop” >>%HJREG%
ECHO “Programs”=“C:\WINDOWS\Start Menu\Programs” >>%HJREG%
ECHO “Fonts”=“C:\WINDOWS\Fonts” >>%HJREG%
ECHO “Startup”=“C:\WINDOWS\Start Menu\Programs\启动” >>%HJREG%
ECHO “Start Menu”=“C:\WINDOWS\Start Menu” >>%HJREG%
ECHO “Templates”=“C:\WINDOWS\ShellNew” >>%HJREG%
ECHO “Recent”=“C:\WINDOWS\Recent” >>%HJREG%
ECHO “SendTo”=“C:\WINDOWS\SendTo” >>%HJREG%
ECHO “NetHood”=“C:\WINDOWS\NetHood” >>%HJREG%
IF %CLR%==2 GOTO REGLB1
ECHO “Personal”=“%HOME%\” >>%HJREG%
ECHO “AppData”=“%HOME%\Application Data” >>%HJREG%
ECHO “Cache”=“%HOME%\Temporary Internet Files” >>%HJREG%
ECHO “Cookies”=“%HOME%\Cookies” >>%HJREG%
ECHO “History”=“%HOME%\History” >>%HJREG%
ECHO “Favorites”=“%HOME%\Favorites” >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders] >>%HJREG%
:REGLB1
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\Config\0001\Enum\ACPI*PNP0700\0] >>%HJREG%
ECHO “FloppyFastBoot”=hex:01,00,00,00 >>%HJREG%
ECHO. >> %HJREG%
REM ECHO [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer] >>%HJREG%
REM ECHO “NoDrives”=hex:01,00,00,00 >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run] >>%HJREG%
ECHO “LoadPowerProfile”=“” >>%HJREG%
ECHO “ScanRegistry”=“” >>%HJREG%
ECHO “SchedulingAgent”=“” >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunServices] >>%HJREG%
ECHO. >> %HJREG%
REM =========================================
REM CHN
ECHO [HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\VNETSUP] >>%HJREG%
REM ======ECHO “Workgroup”=“SCHOOL” >>%HJREG%
ECHO “StaticVxD”=“vnetsup.vxd” >>%HJREG%
ECHO “ComputerName”=“%USN%” >>%HJREG%
ECHO “Comment”=“%USN%” >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\System\CurrentControlSet\control\ComputerName\ComputerName] >>%HJREG%
ECHO. >> %HJREG%
REM LOGON
ECHO [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices] >>%HJREG%
ECHO “Tweak UI”=“RUNDLL32.EXE TWEAKUI.CPL,TweakLogon” >>%HJREG%
IF NOT EXIST C:\WINDOWS\SYSTEM\TWEAKUI.CPL ECHO “Tweak UI”=“” >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\Network\Logon] >>%HJREG%
ECHO “PrimaryProvider”=“Microsoft Network” >>%HJREG%
ECHO “LMLogon”=hex:00,00,00,00 >>%HJREG%
ECHO “DontShowLastUser”=dword:00000000 >>%HJREG%
ECHO “UserProfiles”=dword:00000000 >>%HJREG%
ECHO “UserName”=“%USN%” >>%HJREG%
ECHO. >> %HJREG%
ECHO [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Winlogon] >>%HJREG%
ECHO “AutoAdminLogon”=“1” >>%HJREG%
ECHO “DefaultUserName”=“%USN%” >>%HJREG%
ECHO “DefaultPassword”=“” >>%HJREG%
ECHO. >> %HJREG%
ECHO. >> %HJREG%
REM PRO
ECHO [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProfileList%USN%] >>%HJREG%
ECHO “ProfileImagePath”=“%HOME%\” >>%HJREG%
ECHO. >> %HJREG%
CALL C:\WINDOWS\REGPATCH.BAT
:myend
REGEDIT /L:%REGDIR%\system.dat %HJREG% >NUL
REM 注册表设定结束
CLS
IF EXIST %TEMP%\HJ.BAT A:\WINBOOT\ATTRIB -H -S -R %TEMP%\HJ.BAT >NUL
CLS
A:\WINBOOT\COPYER A:\WINBOOT\HJ.BAT %TEMP%\HJ.BAT >NUL
choice /C:YN /T:Y,03 Hit N and Ctrl-C not to launch Windows (stop the batch) >NUL
%TEMP%\HJ.BAT
:THEEND
无盘论谈就是要这样的贴子而不是JS和软件。谢谢
是不是删掉了。
YIHOME坚决支持。
因为这只提供HTTP://的URL链接,大家告诉我上传地址吧!
FTP://218。10。147。120
user//chinaemu.net
218.10.147.120
user/chinaemu.net
补充:
里面的upload目录有写的权限!
我好心急呀。:expr001:
硬件的PNP
无盘98一样作,尽管我做的是无盘97。suboot中的windows.zip可是一个秘密,在wu.bat中怎么用,这就是启动的关键,也就是我省掉的那两行。。。。
上传windows.zip
