catalyst 5500 VLAN 的配置
cisco5505> (enable) sh config
This command shows non-default configurations only.
Use ‘show config all’ to show both default and non-default configurations.
begin
***** NON-DEFAULT CONFIGURATION *****
#time: Thu Apr 5 2001, 01:45:54
#version 6.1(1)
set option fddi-user-pri enabled
set banner motd ^C
cisco5505(catalyst 5505)
^C
#errordetection
set errordetection portcounter enable
#system
set system name cisco5505
#frame distribution method
set port channel all distribution mac both
#vtp
set vtp domain tzb
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 10 name servers type ethernet mtu 1500 said 100010 state active
set vlan 20 name LD type ethernet mtu 1500 said 100020 state active
set vlan 30 name 2j type ethernet mtu 1500 said 100030 state active
set vlan 40 name info type ethernet mtu 1500 said 100040 state active
set vlan 50 name 1j type ethernet mtu 1500 said 100050 state active
set vlan 60 name 3j type ethernet mtu 1500 said 100060 state active
set vlan 70 name 4j type ethernet mtu 1500 said 100070 state active
set vlan 80 name 5j type ethernet mtu 1500 said 100080 state active
set vlan 90 name 6j type ethernet mtu 1500 said 100090 state active
set vlan 100 name BGT type ethernet mtu 1500 said 100100 state active
set vlan 110 name YJS type ethernet mtu 1500 said 100110 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state activ
e stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active st
p ibm
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state acti
ve mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 1 192.168.1.250/255.255.255.0 192.168.1.255
set interface sl0 193.168.10.250 255.255.0.0
set ip route 0.0.0.0/0.0.0.0 192.168.1.254
#set boot command
set boot auto-config non-recurring
#mls
set mls nde disable
default port status is enable
#module 1 : 2-port 1000BaseX Supervisor IIIG
set trunk 1/1 desirable dot1q 1-1005
set trunk 1/2 desirable dot1q 1-1005
#module 2 : 3-port 1000BaseX Ethernet
set trunk 2/1 desirable negotiate 1-1005
set trunk 2/2 desirable negotiate 1-1005
set trunk 2/3 desirable negotiate 1-1005
#module 3 : 24-port 10/100BaseTX Ethernet
set vlan 10 3/9-13
set vlan 20 3/3-8
set vlan 30 3/2
set vlan 40 3/14-15
set vlan 50 3/16-17
set vlan 70 3/18-19
set vlan 80 3/20-21
set vlan 90 3/22-23
set vlan 100 3/24
#module 4 : 1-port Route Switch
#module 5 empty
#module 15 empty
#module 16 empty
end
cisco5505> (enable)
5505RSM#sh run
Building configuration…
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname 5505RSM
enable secret 5 $1$pUj7$9rSWBnoLQQA12CSAbCJHR0
enable password cisco5505
ip subnet-zero
ip cef
interface Vlan1
ip address 192.168.1.254 255.255.255.0
no ip directed-broadcast
no ip route-cache cef
interface Vlan10
ip address 192.168.10.254 255.255.255.0
interface Vlan20
ip address 192.168.20.254 255.255.255.0
interface Vlan30
ip address 193.168.10.254 255.255.255.0
interface Vlan40
ip address 192.168.40.254 255.255.255.0
interface Vlan50
ip address 192.168.50.254 255.255.255.0
interface Vlan60
ip address 192.168.60.254 255.255.255.0
interface Vlan70
ip address 192.168.70.250 255.255.255.0
interface Vlan80
ip address 192.168.80.254 255.255.255.0
interface Vlan90
ip address 192.168.90.254 255.255.255.0
interface Vlan100
ip address 192.168.100.254 255.255.255.0
interface Vlan110
ip address 192.168.110.254 255.255.255.0
router rip
version 2
network 192.168.1.0
network 192.168.10.0
network 192.168.20.0
network 192.168.40.0
network 192.168.50.0
network 192.168.60.0
network 192.168.70.0
network 192.168.80.0
network 192.168.90.0
network 192.168.100.0
network 192.168.110.0
network 193.168.10.0
ip classless
no ip http server
access-list 101 deny ip 192.168.0.0 0.0.255.255 193.168.0.0 0.0.255.255
access-list 102 deny ip 193.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
line con 0
transport input none
line aux 0
line vty 0 4
password 5505
login
end
5505RSM#
