谁能破解Norton ghost for Novell
有哪个能破解Norton ghost for Novell的试用版,试用版不能大于100处理的分区,有了这个工具就方便多了。
联系方法:xiao_lfd@163.net
破了它也没有任何意义
我这里就有破了的,不过我可不愿意把它拿出来浪费别人时间。
This process will let you swap the disk containing the sys volume with another disk in the same server. Very useful for upgrading server hard drives without using tape. (I’ve modified this to take into account the likely need for the replacement drive to be a DOS boot drive with the OS)
  1. Install the new drive in the server.
  2. Using FDISK, create a DOS partition – say 100M.
  3. Format the DOS partition with /S to include boot DOS files.
  4. Copy all files from the ‘to be replaced’ DOS partition over to the new drive with something like XCOPY C:*.* D:\ /S /E /V
  5. Restart Netware (from the original C drive).
  6. Create a netware partition on the new drive.
  7. Create a “newsys” volume on the new drive.
NOTE: Remember to add long file name support on the new volume if you had it on the original volume.
:sunglasses: Copy data from sys to newsys – note! Ncopy will not retain rights.
You will either need to use something like Arcserve’s copy function, or something like fstrust. (FSTrust can be found at http://www.dreamlan.com).
If rights are not an issue, then ncopy will work fine.
Also, Novell provides a downloadable utility for handling rights as well – TCOPY2.EXE (track it down at:
http://support.novell.com/cgi-bin/search/patlstdownload?file=/pub/updates/nwos/inw411/tcopy2.exe
  1. Use the “dsmaint” of install to backup NDS to newsys:system
  2. Dismount sys
  3. Dismount newsys
  4. Rename sys to oldsys
  5. Rename newsys to sys
  6. Use the "dsmaint’ of install to restore NDS
  7. Restart server
  8. Add license(s) back
