请问哪位能提供一下张的4。2试用版本。
我想试一试。
我有,网友发来的,可惜是演示版本,只能上4用户。
转贴一篇:
自已动手破解张裕飞 RPL98 安装工具
前提:做好了四用户启动!工作站能正常工作
1:改win.bat:
把:wpwin98.exe 改为:regedit c:%user%.ip
2.改user0x.ip:为:
REGEDIT4
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run]
“ScanRegistry”=“”
“LoadPowerProfile”=“”
“SchedulingAgent”=“”
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunServices]
[HKEY_LOCAL_MACHINE\Network\Logon]
“username”=“USER01”
[HKEY_USERS.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders]
“AppData”=“S:\Application Data”
“Recent”=“S:\Recent”
“Cache”=“S:\Temporary Internet Files”
“Cookies”=“S:\Cookies”
“History”=“S:\History”
“Personal”=“S:\My Documents”
[HKEY_USERS.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
[HKEY_USERS.DEFAULT\Software\Microsoft\Windows\CurrentVersion\ProfileReconciliation\AppData]
“DefaultDir”=“S:\Application Data”
[HKEY_USERS.DEFAULT\Software\Microsoft\Windows\CurrentVersion\ProfileReconciliation\Cookies]
“DefaultDir”=“S:\Cookies”
[HKEY_USERS.DEFAULT\Software\Microsoft\Windows\CurrentVersion\ProfileReconciliation\History]
“DefaultDir”=“S:\History”
[HKEY_USERS.DEFAULT\Software\Microsoft\WAB\WAB4\Wab File Name]
@=“S:\Application Data\Microsoft\Address Book\user01.wab”
[HKEY_USERS.DEFAULT\Identities{3FA971E0-214F-11D5-B9A6-BC8E1E75FA61}\Software\Microsoft\Outlook Express\5.0]
“Store Root”=“S:\Application Data\Identities\{3FA971E0-214F-11D5-B9A6-BC8E1E75FA61}\Microsoft\Outlook Express\”
“transport”=“*nwlink,ndishlp.sys”
“netcard”=“”
“LoadRMDrivers”=hex:00,00,00,00
“preferredredir”=“VREDIR”
“SetupNPath”=“C:\WINDOWS\”
“StaticDrive”=“C,c”
“SetupN”=hex:01
“Transition”=hex:01
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0000]
“DevLoader”=“*ndis”
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0001]
“DevLoader”=“*ndis”
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0002]
“DevLoader”=“*ndis”
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0003]
“DevLoader”=“*ndis”
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\0004]
“DevLoader”=“*ndis”
注:上面的一句可多写到0009,也可只写一句,这就得看你的实际网卡位置了!
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\LHOOK]
“StaticVxD”=“lhook.vxd”
“Start”=hex:00
“NetClean”=hex:01
还有一句忘了:就是关于电脑名的注册表!自已查一下!加入就行了!
要不就不能用netbeui协议了!
3.把wpwin98.exe运行后d:盘下的lhook.vxd复制到windows\system下。
4.重启所有工作站!一切搞定!
这本就是很简单的问题,还有呢!IP啦
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\NetTrans\000?]
“IPAddress”=“192.168.0.?”
“IPMask”=“255.255.255.0”
最关键的是下面的这两个,其它的大家应该是要知道的
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Net\00??]
“DevLoader”=“*ndis”
章可是不管多少统一加到0015,根据网卡位置而定
“Start”=hex:00
“ComputerName”=“USER01”
楼上凤凰:
一、USER0X.IP如何打开呢?
二、第二点下面的注册表内容要加到哪儿,可否做个脚本 .reg 文件双击运行?
三、能不能说说大致的具体操作?
你看看我的帖子前四个汉字写的什么??
这是老版本的方法吗?对4.2有效吗???.用这不如用张的4.0破解
user0x.IP用记事本打开。
我认为下面的的注册表内容也是加在USER0X.IP中的。
哪有4。0的破解版本呀?太狼,你有吗?
是网友给的,只是四用户演示版,发给你应该没有问题。
