网吧奇遇
Test Page
This page is used to test the proper operation of the Apache Web server after it has been installed. If you can read this page, it means that the Apache Web server installed at this site is working properly.
If you are the administrator of this website:
You may now add content to this directory, and replace this page. Note that until you do so, people visiting your website will see this page, and not your content.
If you have upgraded from Red Hat Linux 6.2 and earlier, then you are seeing this page because the default {DocumentRoot} set in /etc/httpd/conf/httpd.conf
has changed. Any subdirectories which existed under /home/httpd
should now be moved to /var/www
. Alternatively, the contents of /var/www
can be moved to /home/httpd
, and the configuration file can be updated accordingly.
If you are a member of the general public:
The fact that you are seeing this page indicates that the website you just visited is either experiencing problems, or is undergoing routine maintenance.
If you would like to let the administrators of this website know that you’ve seen this page instead of the page you expected, you should send them e-mail. In general, mail sent to the name “webmaster” and directed to the website’s domain should reach the appropriate person.
For example, if you experienced problems while visiting http://www.example.com, you should send e-mail to “webmaster@example.com”.
The Apache {documentation} has been included with this distribution.
For documentation and information on Red Hat Linux, please visit the {Red Hat, Inc.} website. The manual for Red Hat Linux is available {here}.
You are free to use the image below on an Apache-powered Web server. Thanks for using Apache!
{[[ Powered
by Apache ]]}
You are free to use the image below on a Red Hat Linux-powered Web server. Thanks for using Red Hat Linux!
{[[ Powered
by Red Hat Linux ]]}
以上是有盘win98se在某无盘网吧(斯普林软件),通过代理服务器打开某网页时出现的文字。经测试通过代理服务器登录FTP没问题
ip:192.168.125.99 网关/dns:192.168.125.1 PING通
这是什么奇遇呀,它只是另外用一台机子装了redhat linux系统做代理而已,有什么大惊小怪的,好像主人不太会用!主页没设置好,还是系统本来的测试页!
我看也是!
有兄,sygate只能做一件事,就是上网路由,而redhat linux可以做好多事的,他现在只用apache做电影和文件服务器还有web服务器都行呀!
