登录时提示“提供的域密码不正确”
登录时提示“提供的域密码不正确”
经常出现这样的问题,请问什么原因所致。和删掉WIN服务有关吗?(因共享上网的需要删了)
协议没配好
我用的是WIN2000+PXE98,是指有盘98的协议没配好吗?
可在设置共享上网前是正常的,而有盘98未做任何改动
我做了,如果是win98上传的时候要把服务器的远程登陆和路由打开,而传完了时候又得把这玩意半了否则启不了
下面是微软的做法:
简单说:
1、在工作站,WIN98上,网卡的IPX上启用NETBIOS。
2、在HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Vxd\VNETSUP
下增加一个字符串键值:
DirectHost=0
就一切OK
一般这种问题比较少。
SYMPTOMS
When you attempt to log on to a Windows 2000 domain or a mixed Windows 2000\Microsoft Windows NT 4.0 domain, you may receive the following error message:
The domain password you supplied is not correct, or access to your logon server has been denied.
This problem may be intermittent in a mixed environment (Windows 2000/Windows NT 4.0), because Windows NT 4.0 does not exhibit this problem.
RESOLUTION
To resolve this behavior, use either of the following methods:
Use another protocol instead of IPX.
Add NetBIOS support to the IPX protocol on the Microsoft Windows 95\98 client, and disable direct hosting.
How to Disable Direct Hosting
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
To disable direct hosting in Windows 95\98, use the following steps:
Start Registry Editor (click Start, click Run, type regedit, and then click OK).
Locate the following registry key:
Click VNETSUP.
On the Edit menu, click New, and then click String Value. A new value is displayed in the right-hand pane.
If necessary, right-click the new item, click Rename, type directhost, and then press ENTER.
Right-click DirectHost, and then click Modify. The Edit String dialog box is displayed.
Type 0, and then click OK.
Quit Registry Editor.
NOTE: Restart Windows 95\98 for the changes to take effect.
STATUS
