老大,你好劲呀,如此功力,使我大深深佩服,就好像教练一样.
我也不清楚,但方法我已经说了,就是下载制作模拟软盘,试了不就知道了。
网之鹰版主,没有9008呀,用NE2000的可以吗?
老大,谢谢你的文章。我的DM9008原来就是NE2000兼容网卡,我今天试过了,谢谢。
panhh兄,如何在服务器上获取工作站的网卡的MAC地址呢?如果有办法,我想就有希望做成象启明星一样的管理器了。
在bootp/dhcpl等等协议中,最初无盘站启动时都要向服务器发送一个寻找ip的帧,只要编程监听对应的服务器端口,就可以得到无盘站启动时的帧其中就是相应的mac地址。linux中有bootp/dhcp有源程序,就看你能不能读懂,能不能自己编写了。
所有协议都是公开的,只不过要读E文了。
Network Working Group Bill Croft (Stanford University)
Request for Comments: 951 John Gilmore (Sun Microsystems)
September 1985
BOOTSTRAP PROTOCOL (BOOTP)
Status of this Memo
This RFC suggests a proposed protocol for the ARPA-Internet
community, and requests discussion and suggestions for improvements.
Distribution of this memo is unlimited. -
Overview
This RFC describes an IP/UDP bootstrap protocol (BOOTP) which allows
a diskless client machine to discover its own IP address, the address
of a server host, and the name of a file to be loaded into memory and
executed. The bootstrap operation can be thought of as consisting of
TWO PHASES. This RFC describes the first phase, which could be
labeled ‘address determination and bootfile selection’. After this
address and filename information is obtained, control passes to the
second phase of the bootstrap where a file transfer occurs. The file
transfer will typically use the TFTP protocol [9], since it is
intended that both phases reside in PROM on the client. However
BOOTP could also work with other protocols such as SFTP [3] or
FTP [6].We suggest that the client’s PROM software provide a way to do a
complete bootstrap without ‘user’ interaction. This is the type of
boot that would occur during an unattended power-up. A mechanism
should be provided for the user to manually supply the necessary
address and filename information to bypass the BOOTP protocol and
enter the file transfer phase directly. If non-volatile storage is
available, we suggest keeping default settings there and bypassing
the BOOTP protocol unless these settings cause the file transfer
phase to fail. If the cached information fails, the bootstrap should
fall back to phase 1 and use BOOTP.Here is a brief outline of the protocol:
A single packet exchange is performed. Timeouts are used to
retransmit until a reply is received. The same packet field
layout is used in both directions. Fixed length fields of maximum
reasonable length are used to simplify structure definition and
parsing. -
An ‘opcode’ field exists with two values. The client
broadcasts a ‘bootrequest’ packet. The server then answers with a
‘bootreply’ packet. The bootrequest contains the client’s
hardware address and its IP address, if known.
RFC 951 September 1985
Bootstrap Protocol
3. The request can optionally contain the name of the server the
client wishes to respond. This is so the client can force the
boot to occur from a specific host (e.g. if multiple versions of
the same bootfile exist or if the server is in a far distant
net/domain). The client does not have to deal with name / domain
services; instead this function is pushed off to the BOOTP server.
4. The request can optionally contain the 'generic' filename to be
booted. For example 'unix' or 'ethertip'. When the server sends
the bootreply, it replaces this field with the fully qualified
path name of the appropriate boot file. In determining this name,
the server may consult his own database correlating the client's
address and filename request, with a particular boot file
customized for that client. If the bootrequest filename is a null
string, then the server returns a filename field indicating the
'default' file to be loaded for that client.
5. In the case of clients who do not know their IP addresses, the
server must also have a database relating hardware address to IP
address. This client IP address is then placed into a field in
the bootreply.
6. Certain network topologies (such as Stanford's) may be such
that a given physical cable does not have a TFTP server directly
attached to it (e.g. all the gateways and hosts on a certain cable
may be diskless). With the cooperation of neighboring gateways,
BOOTP can allow clients to boot off of servers several hops away,
through these gateways. See the section 'Booting Through
Gateways' below. This part of the protocol requires no special
action on the part of the client. Implementation is optional and
requires a small amount of additional code in gateways and
servers.
Packet Format
All numbers shown are decimal, unless indicated otherwise. The BOOTP
packet is enclosed in a standard IP [8] UDP [7] datagram. For
simplicity it is assumed that the BOOTP packet is never fragmented.
Any numeric fields shown are packed in ‘standard network byte order’,
i.e. high order bits are sent first.In the IP header of a bootrequest, the client fills in its own IP
source address if known, otherwise zero. When the server address is
unknown, the IP destination address will be the ‘broadcast address’
255.255.255.255. This address means ‘broadcast on the local cable,
(I don’t know my net number)’ [4].
Bootstrap Protocol
The UDP header contains source and destination port numbers. The
BOOTP protocol uses two reserved port numbers, ‘BOOTP client’ (68)
and ‘BOOTP server’ (67). The client sends requests using ‘BOOTP
server’ as the destination port; this is usually a broadcast. The
server sends replies using ‘BOOTP client’ as the destination port;
depending on the kernel or driver facilities in the server, this may
or may not be a broadcast (this is explained further in the section
titled ‘Chicken/Egg issues’ below). The reason TWO reserved ports
are used, is to avoid ‘waking up’ and scheduling the BOOTP server
daemons, when a bootreply must be broadcast to a client. Since the
server and other hosts won’t be listening on the ‘BOOTP client’ port,
any such incoming broadcasts will be filtered out at the kernel
level. We could not simply allow the client to pick a ‘random’ port
number for the UDP source port field; since the server reply may be
broadcast, a randomly chosen port number could confuse other hosts
that happened to be listening on that port.
The UDP length field is set to the length of the UDP plus BOOTP
portions of the packet. The UDP checksum field can be set to zero by
the client (or server) if desired, to avoid this extra overhead in a
PROM implementation. In the ‘Packet Processing’ section below the
phrase ‘[UDP checksum.]’ is used whenever the checksum might be
verified/computed.
FIELD BYTES DESCRIPTION
op 1 packet op code / message type.
1 = BOOTREQUEST, 2 = BOOTREPLY
htype 1 hardware address type,
see ARP section in "Assigned Numbers" RFC.
'1' = 10mb ethernet
hlen 1 hardware address length
(eg '6' for 10mb ethernet).
hops 1 client sets to zero,
optionally used by gateways
in cross-gateway booting.
xid 4 transaction ID, a random number,
used to match this boot request with the
responses it generates.
secs 2 filled in by client, seconds elapsed since
client started trying to boot.
Bootstrap Protocol
-- 2 unused
ciaddr 4 client IP address;
filled in by client in bootrequest if known.
yiaddr 4 'your' (client) IP address;
filled by server if client doesn't
know its own address (ciaddr was 0).
siaddr 4 server IP address;
returned in bootreply by server.
giaddr 4 gateway IP address,
used in optional cross-gateway booting.
chaddr 16 client hardware address,
filled in by client.
sname 64 optional server host name,
null terminated string.
file 128 boot file name, null terminated string;
'generic' name or null in bootrequest,
fully qualified directory-path
name in bootreply.
vend 64 optional vendor-specific area,
e.g. could be hardware type/serial on request,
or 'capability' / remote file system handle
on reply. This info may be set aside for use
by a third phase bootstrap or kernel.
Chicken / Egg Issues
How can the server send an IP datagram to the client, if the client
doesnt know its own IP address (yet)? Whenever a bootreply is being
sent, the transmitting machine performs the following operations:-
If the client knows its own IP address (‘ciaddr’ field is
nonzero), then the IP can be sent ‘as normal’, since the client
will respond to ARPs [5]. -
If the client does not yet know its IP address (ciaddr zero),
then the client cannot respond to ARPs sent by the transmitter of
the bootreply. There are two options:a. If the transmitter has the necessary kernel or driver hooks
Bootstrap Protocol
to 'manually' construct an ARP address cache entry, then it can
fill in an entry using the 'chaddr' and 'yiaddr' fields. Of
course, this entry should have a timeout on it, just like any
other entry made by the normal ARP code itself. The
transmitter of the bootreply can then simply send the bootreply
to the client's IP address. UNIX (4.2 BSD) has this
capability.
b. If the transmitter lacks these kernel hooks, it can simply
send the bootreply to the IP broadcast address on the
appropriate interface. This is only one additional broadcast
over the previous case.
Client Use of ARP
The client PROM must contain a simple implementation of ARP, e.g. the
address cache could be just one entry in size. This will allow a
second-phase-only boot (TFTP) to be performed when the client knows
the IP addresses and bootfile name.Any time the client is expecting to receive a TFTP or BOOTP reply, it
should be prepared to answer an ARP request for its own IP to
hardware address mapping (if known).Since the bootreply will contain (in the hardware encapsulation) the
hardware source address of the server/gateway, the client MAY be able
to avoid sending an ARP request for the server/gateway IP address to
be used in the following TFTP phase. However this should be treated
only as a special case, since it is desirable to still allow a
second-phase-only boot as described above. -
Comparison to RARP
An earlier protocol, Reverse Address Resolution Protocol (RARP) [1]
was proposed to allow a client to determine its IP address, given
that it knew its hardware address. However RARP had the disadvantage
that it was a hardware link level protocol (not IP/UDP based). This
means that RARP could only be implemented on hosts containing special
kernel or driver modifications to access these ‘raw’ packets. Since
there are many network kernels existent now, with each source
maintained by different organizations, a boot protocol that does not
require kernel modifications is a decided advantage.BOOTP provides this hardware to IP address lookup function, in
addition to the other useful features described in the sections
above.
Bootstrap Protocol
Packet Processing
7.1. Client Transmission
Before setting up the packet for the first time, it is a good idea
to clear the entire packet buffer to all zeros; this will place
all fields in their default state. The client then creates a
packet with the following fields.The IP destination address is set to 255.255.255.255. (the
broadcast address) or to the server’s IP address (if known). The
IP source address and ‘ciaddr’ are set to the client’s IP address
if known, else 0. The UDP header is set with the proper length;
source port = ‘BOOTP client’ port destination port = ‘BOOTP
server’ port.‘op’ is set to ‘1’, BOOTREQUEST. ‘htype’ is set to the hardware
address type as assigned in the ARP section of the “Assigned
Numbers” RFC. ‘hlen’ is set to the length of the hardware address,
e.g. ‘6’ for 10mb ethernet.‘xid’ is set to a ‘random’ transaction id. ‘secs’ is set to the
number of seconds that have elapsed since the client has started
booting. This will let the servers know how long a client has
been trying. As the number gets larger, certain servers may feel
more ‘sympathetic’ towards a client they don’t normally service.
If a client lacks a suitable clock, it could construct a rough
estimate using a loop timer. Or it could choose to simply send
this field as always a fixed value, say 100 seconds.If the client knows its IP address, ‘ciaddr’ (and the IP source
address) are set to this value. ‘chaddr’ is filled in with the
client’s hardware address.If the client wishes to restrict booting to a particular server
name, it may place a null-terminated string in ‘sname’. The name
used should be any of the allowable names or nicknames of the
desired host.The client has several options for filling the ‘file’ name field.
If left null, the meaning is ‘I want to boot the default file for
my machine’. A null file name can also mean ‘I am only interested
in finding out client/server/gateway IP addresses, I dont care
about file names’.The field can also be a ‘generic’ name such as ‘unix’ or
Bootstrap Protocol
'gateway'; this means 'boot the named program configured for my
machine'. Finally the field can be a fully directory qualified
path name.
The 'vend' field can be filled in by the client with
vendor-specific strings or structures. For example the machine
hardware type or serial number may be placed here. However the
operation of the BOOTP server should not DEPEND on this
information existing.
If the 'vend' field is used, it is recommended that a 4 byte
'magic number' be the first item within 'vend'. This lets a
server determine what kind of information it is seeing in this
field. Numbers can be assigned by the usual 'magic number'
process --you pick one and it's magic. A different magic number
could be used for bootreply's than bootrequest's to allow the
client to take special action with the reply information.
[UDP checksum.]
7.2. Client Retransmission Strategy
If no reply is received for a certain length of time, the client
should retransmit the request. The time interval must be chosen
carefully so as not to flood the network. Consider the case of a
cable containing 100 machines that are just coming up after a
power failure. Simply retransmitting the request every four
seconds will inundate the net.
As a possible strategy, you might consider backing off
exponentially, similar to the way ethernet backs off on a
collision. So for example if the first packet is at time 0:00,
the second would be at :04, then :08, then :16, then :32, then
:64. You should also randomize each time; this would be done
similar to the ethernet specification by starting with a mask and
'and'ing that with with a random number to get the first backoff.
On each succeeding backoff, the mask is increased in length by one
bit. This doubles the average delay on each backoff.
After the 'average' backoff reaches about 60 seconds, it should be
increased no further, but still randomized.
Before each retransmission, the client should update the 'secs'
field. [UDP checksum.]
Bootstrap Protocol
7.3. Server Receives BOOTREQUEST
[UDP checksum.] If the UDP destination port does not match the
'BOOTP server' port, discard the packet.
If the server name field (sname) is null (no particular server
specified), or sname is specified and matches our name or
nickname, then continue with packet processing.
If the sname field is specified, but does not match 'us', then
there are several options:
1. You may choose to simply discard this packet.
2. If a name lookup on sname shows it to be on this same cable,
discard the packet.
3. If sname is on a different net, you may choose to forward
the packet to that address. If so, check the 'giaddr' (gateway
address) field. If 'giaddr' is zero, fill it in with my
address or the address of a gateway that can be used to get to
that net. Then forward the packet.
If the client IP address (ciaddr) is zero, then the client does
not know its own IP address. Attempt to lookup the client
hardware address (chaddr, hlen, htype) in our database. If no
match is found, discard the packet. Otherwise we now have an IP
address for this client; fill it into the 'yiaddr' (your IP
address) field.
We now check the boot file name field (file). The field will be
null if the client is not interested in filenames, or wants the
default bootfile. If the field is non-null, it is used as a
lookup key in a database, along with the client's IP address. If
there is a default file or generic file (possibly indexed by the
client address) or a fully-specified path name that matches, then
replace the 'file' field with the fully-specified path name of the
selected boot file. If the field is non-null and no match was
found, then the client is asking for a file we dont have; discard
the packet, perhaps some other BOOTP server will have it.
The 'vend' vendor-specific data field should now be checked and if
a recognized type of data is provided, client-specific actions
should be taken, and a response placed in the 'vend' data field of
the reply packet. For example, a workstation client could provide
Bootstrap Protocol
an authentication key and receive from the server a capability for
remote file access, or a set of configuration options, which can
be passed to the operating system that will shortly be booted in.
Place my (server) IP address in the 'siaddr' field. Set the 'op'
field to BOOTREPLY. The UDP destination port is set to 'BOOTP
client'. If the client address 'ciaddr' is nonzero, send the
packet there; else if the gateway address 'giaddr' is nonzero, set
the UDP destination port to 'BOOTP server' and send the packet to
'giaddr'; else the client is on one of our cables but it doesnt
know its own IP address yet --use a method described in the 'Egg'
section above to send it to the client. If 'Egg' is used and we
have multiple interfaces on this host, use the 'yiaddr' (your IP
address) field to figure out which net (cable/interface) to send
the packet to. [UDP checksum.]
7.4. Server/Gateway Receives BOOTREPLY
[UDP checksum.] If 'yiaddr' (your [the client's] IP address)
refers to one of our cables, use one of the 'Egg' methods above to
forward it to the client. Be sure to send it to the 'BOOTP
client' UDP destination port.
7.5. Client Reception
Don't forget to process ARP requests for my own IP address (if I
know it). [UDP checksum.] The client should discard incoming
packets that: are not IP/UDPs addressed to the boot port; are not
BOOTREPLYs; do not match my IP address (if I know it) or my
hardware address; do not match my transaction id. Otherwise we
have received a successful reply. 'yiaddr' will contain my IP
address, if I didnt know it before. 'file' is the name of the
file name to TFTP 'read request'. The server address is in
'siaddr'. If 'giaddr' (gateway address) is nonzero, then the
packets should be forwarded there first, in order to get to the
server.
Booting Through Gateways
This part of the protocol is optional and requires some additional
code in cooperating gateways and servers, but it allows cross-gateway
booting. This is mainly useful when gateways are diskless machines.
Gateways containing disks (e.g. a UNIX machine acting as a gateway),
might as well run their own BOOTP/TFTP servers.Gateways listening to broadcast BOOTREQUESTs may decide to forward or
rebroadcast these requests ‘when appropriate’. For example, the
Bootstrap Protocol
gateway could have, as part of his configuration tables, a list of
other networks or hosts to receive a copy of any broadcast
BOOTREQUESTs. Even though a ‘hops’ field exists, it is a poor idea
to simply globally rebroadcast the requests, since broadcast loops
will almost certainly occur.
The forwarding could begin immediately, or wait until the ‘secs’
(seconds client has been trying) field passes a certain threshold.
If a gateway does decide to forward the request, it should look at
the ‘giaddr’ (gateway IP address) field. If zero, it should plug its
own IP address (on the receiving cable) into this field. It may also
use the ‘hops’ field to optionally control how far the packet is
reforwarded. Hops should be incremented on each forwarding. For
example, if hops passes ‘3’, the packet should probably be discarded.
[UDP checksum.]
Here we have recommended placing this special forwarding function in
the gateways. But that does not have to be the case. As long as
some ‘BOOTP forwarding agent’ exists on the net with the booting
client, the agent can do the forwarding when appropriate. Thus this
service may or may not be co-located with the gateway.
In the case of a forwarding agent not located in the gateway, the
agent could save himself some work by plugging the broadcast address
of the interface receiving the bootrequest into the ‘giaddr’ field.
Thus the reply would get forwarded using normal gateways, not
involving the forwarding agent. Of course the disadvantage here is
that you lose the ability to use the ‘Egg’ non-broadcast method of
sending the reply, causing extra overhead for every host on the
client cable.
Sample BOOTP Server Database
As a suggestion, we show a sample text file database that the BOOTP
server program might use. The database has two sections, delimited
by a line containing an percent in column 1. The first section
contains a ‘default directory’ and mappings from generic names to
directory/pathnames. The first generic name in this section is the
‘default file’ you get when the bootrequest contains a null ‘file’
string.The second section maps hardware addresstype/address into an
ipaddress. Optionally you can also overide the default generic name
by supplying a ipaddress specific genericname. A ‘suffix’ item is
also an option; if supplied, any generic names specified by the
client will be accessed by first appending ‘suffix’ to the ‘pathname’
Bootstrap Protocol
appropriate to that generic name. If that file is not found, then
the plain ‘pathname’ will be tried. This ‘suffix’ option allows a
whole set of custom generics to be setup without a lot of effort.
Below is shown the general format; fields are delimited by one or
more spaces or tabs; trailing empty fields may be omitted; blank
lines and lines beginning with ‘#’ are ignored.
# comment line
homedirectory
genericname1 pathname1
genericname2 pathname2
% end of generic names, start of address mappings
hostname1 hardwaretype hardwareaddr1 ipaddr1 genericname suffix
hostname2 hardwaretype hardwareaddr2 ipaddr2 genericname suffix
Here is a specific example. Note the ‘hardwaretype’ number is the
same as that shown in the ARP section of the ‘Assigned Numbers’ RFC.
The ‘hardwaretype’ and ‘ipaddr’ numbers are in decimal;
‘hardwareaddr’ is in hex.
# last updated by smith
/usr/boot
vmunix vmunix
tip ethertip
watch /usr/diag/etherwatch
gate gate.
hamilton 1 02.60.8c.06.34.98 36.19.0.5
burr 1 02.60.8c.34.11.78 36.44.0.12
101-gateway 1 02.60.8c.23.ab.35 36.44.0.32 gate 101
mjh-gateway 1 02.60.8c.12.32.bc 36.42.0.64 gate mjh
welch-tipa 1 02.60.8c.22.65.32 36.47.0.14 tip
welch-tipb 1 02.60.8c.12.15.c8 36.46.0.12 tip
In the example above, if ‘mjh-gateway’ does a default boot, it will
get the file ‘/usr/boot/gate.mjh’.
Bootstrap Protocol
- Acknowledgements
Ross Finlayson (et. al.) produced two earlier RFC’s discussing TFTP
bootstraping [2] using RARP [1].
We would also like to acknowledge the previous work and comments of
Noel Chiappa, Bob Lyon, Jeff Mogul, Mark Lewis, and David Plummer.
REFERENCES
Ross Finlayson, Timothy Mann, Jeffrey Mogul, Marvin Theimer. A
Reverse Address Resolution Protocol. RFC 903, NIC, June, 1984. -
Ross Finlayson. Bootstrap Loading using TFTP. RFC 906, NIC,
June, 1984. -
Mark Lottor. Simple File Transfer Protocol. RFC 913, NIC,
September, 1984. -
Jeffrey Mogul. Broadcasting Internet Packets. RFC 919, NIC,
October, 1984. -
David Plummer. An Ethernet Address Resolution Protocol. RFC
826, NIC, September, 1982. -
Jon Postel. File Transfer Protocol. RFC 765, NIC, June, 1980.
Jon Postel. User Datagram Protocol. RFC 768, NIC, August, 1980.
Jon Postel. Internet Protocol. RFC 791, NIC, September, 1981.
K. R. Sollins, Noel Chiappa. The TFTP Protocol. RFC 783, NIC,
June, 1981.
panhh兄,谢谢你的贴子,E文是比较难懂,慢慢看应该没有问题。以后若有什么不懂还需要你的指教。谢过了。
OK!DOWN!!! ![]()
是不是我来晚了。
ftp://xgjx.vicp.net/bootp
中的压缩包已能下载了。
拜读大作,甚感欢欣。
这比bootix的文档实用很多,更没有语言障碍。
补充重要一点:在NT及9X下,默认情况是UDP 67给DHCP或BOOTP,UDP 68未打开,因此在NT及9X下直接使用bootpd32.exe,必然出错,无法运行,只有在services文件中定义此二UDP端口,才可正常使用。在W2K及XP下无需此步。ME下不知。
望老兄考虑写入之,因为好多人更愿意在NT下玩无盘。
您还可以再写一个DHCP版本的,因为DHCP实在是更方便建立与维护。
对了,还有一点,bootp&tftp对机器无特殊要求,所以您也可以把WIN31,NW,LINUX下实现步骤作为advance篇加入,大全嘛,总要考虑进阶及特殊应用。比如NW引导DOS作2K终端,我敢说是个真玩家都乐意转入Etherboot的。
“大全”是有些夸大了,我对NW 基本没用过,所以没有提到。LINUX我是想另写一篇的。这一篇写的时间很紧,所以NT下也没有测试。多谢老兄提醒。
在2000专业版上不可以正常使用bootpd32.exe。请问怎样才可以用呢?
专业版没试过,可能和98一样只能以命令行的形式运行吧,不能以服务的形式。
专业版好象共享也有些问题,有连接数的限制吧。
可以运行,但不可以象你的电子书那样正常运行。要不要设置其它什么呢?
以前能做出NW的BOOTP,可对原理不太懂,今晚看了老大的问章,懂了很多,
谢!!
得益非浅,感激直至!
现在还能提供下载么?
