我用的是WIN2000高级服务器版。用凌心的RPLW2K移植的WINNT4。0的RPL。。
能启动无盘DOS。。在安装无盘95时出现下边的错误。。。
Setup Deteection Error
Error SU-0013
Setup could not create files on your startup drive and cannot set up
Windows.
If you have HPFS or Windows NT file system. you must create an MS-DOS
boot patition. If you have LANtastic server or SuperStor compression.
disable it before running setup .See SETUP.TXT on Setup Disk 1 or the
Windows CD-ROM.
Exit Setup
服务器的分区都是NTFS格式的。。。
请各位高手帮帮忙。。。。告小弟怎么解决。。。不胜感激
