贴不了图
开机提示:This appliction requires a larger buffer for transferring information over the network.You can increase the buffer size by modifying the NetHeapSize setting in your SYSTEM.INI file.
Include or modify the following setting the [386Ehn] section of your SYSTEM.INI file:
NetHeapSize=20
If the NetHeapSize value is still too low,this messaF…
怎么回事?请教了
我在system.ini的[386Ehn]中加上NetHeapSize=1024也不行,也有这个提示。
