1、安装WIN98SE,安装时选自定义安装,不要安装通讯组件(切记)
2、按正常方式安装网卡驱动,注意用网卡驱动盘WIN95a目录下的驱动,不要
选WIN98或WIN98SE下的驱动(大家没有这个驱动,请下载附件里的)
装网卡要重启的,知道吧,把该装的协议全部装好,网卡正常工作了,再看
下面一步。
3、改注册表,在“开始”菜单,选“运行”输入regedit命令,导出注册表,
REGEDIT4
[HKEY_LOCAL_MACHINE\Enum\PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10]
[HKEY_LOCAL_MACHINE\Enum\PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\BUS_00&DEV_0B&FUNC_00]
“Capabilities”=hex:14,00,00,00
“HardwareID”=“PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10,PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC,PCI\VEN_10EC&DEV_8139&REV_10&CC_0200,PCI\VEN_10EC&DEV_8139&CC_020000,PCI\VEN_10EC&DEV_8139&CC_0200”
“CompatibleIDs”=“PCI\VEN_10EC&DEV_8139&REV_10,PCI\VEN_10EC&DEV_8139,PCI\VEN_10EC&CC_020000,PCI\VEN_10EC&CC_0200,PCI\VEN_10EC,PCI\CC_020000,PCI\CC_0200”
“DeviceDesc”=“Realtek RTL8139/810x Family Fast Ethernet NIC”
“HWRevision”=“016”
“Class”=“Net”
“ConfigFlags”=hex:10,00,00,00
“ClassGUID”=“{4d36e972-e325-11ce-bfc1-08002be10318}”
“Driver”=“Net\0000”
“Mfg”=“Realtek”
[HKEY_LOCAL_MACHINE\Enum\PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\BUS_00&DEV_0B&FUNC_00\Bindings]
“NWLINK\0000”=“”
“MSTCP\0000”=“”
[HKEY_LOCAL_MACHINE\Enum\PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\BUS_00&DEV_0B&FUNC_00\LogConfig]
“0000”=hex:00,04,00,00,00,30,00,00,10,00,00,00,04,00,00,00,03,00,0b,00,b8,de,
00,00,30,00,00,00,01,00,00,00,01,00,14,00,00,00,00,dd,ff,00,00,dd,01,00,00,
00,00,ff,ff,ff,00,01,00,00,00,00,00,00,ff,ff,ff,ff,01,00,00,00,14,00,00,00,
24,00,00,00,02,00,00,00,01,00,0c,00,00,e8,ff,e8,00,00,ff,00,00,ff,00,01,00,
00,ff,ff,00,00,ff,00,10,00,00,00,30,00,00,00,01,00,00,00,01,00,14,00,00,c0,
0c,00,ff,ff,0c,00,00,00,00,00,ff,ff,ff,ff,00,40,00,00,00,c0,0c,00,ff,ff,0c,
00,00,00,00,00,ff,00,00,00,00,00,00,00
改成如下的注表:
REGEDIT4
[HKEY_LOCAL_MACHINE\Enum\Root\NET]
[HKEY_LOCAL_MACHINE\Enum\Root\NET\0000]
“DeviceDesc”=“Realtek RTL8139/810X Family PCI Fast Ethernet NIC”
“HWRevision”=“016”
“Class”=“Net”
“Driver”=“Net\0000”
“Mfg”=“Realtek”
[HKEY_LOCAL_MACHINE\Enum\Root\NET\0000\Bindings]
“NWLINK\0000”=“”
“MSTCP\0000”=“”
4、把改好的注册表导入,再删除HKEY_LOCAL_MACHINE\Enum\PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10键
5、删除WINDOWS\INF和windows\inf\other下的,NETRTS。INF和MICROSOFTNETRTS。INF文件(注意我用的是VIA的板术,INTEL的主板装出来有点不一样,但位置是一样的)
6、重新启动,WIN98报找到新硬件(就是第5步删了的网卡),没关系,不要给驱动他装,WIN98就会 说找到了一个未知设备,这正是我们所需要的。
7、检查我的电脑属性,网卡是否工作正常,如果不正常,有感叹号,说明是RTL8139。SYS版本不对,换成我的,就行了。
8、如果网卡工作正常,网卡的PNP就好了。
9、如果看那个未知网卡不顺眼,用这个SYSTEM。INF驱动一下,不要紧张,不会影响我们做好的PNP网卡的。(下载后把SYSTEM。RAR改为SYSTEM。INF)
system.RAR (483 Bytes)
win95a.rar (85.8 KB)
