有一台电信给的prestige 642 adsl modem,因为有路由功能,以前将其调为路由状态。
现需要把它调回原来的rfc1483桥接模式,我是这样做的(按照其公司网站所说的复位方法,根本无法复位,我怀疑复位键坏了:( ):
Menu 1 - General Setup
System Name= changeme
Location=huizhou
Contact Person’s Name=boss
Route IP= no
Route IPX= No
Bridge= yes
Menu 3.2 - TCP/IP and DHCP Ethernet Setup
DHCP Setup
DHCP= none
Client IP Pool Starting Address= N/A
Size of Client IP Pool= N/A
Primary DNS Server= N/A
Secondary DNS Server= N/A
Remote DHCP Server= N/A
TCP/IP Setup:
IP Address= 192.168.1.1
IP Subnet Mask= 255.255.255.0
RIP Direction= Both
Version= RIP-1
Multicast= None
IP Policies=
Edit IP Alias= No
Menu 4 - Internet Access Setup
ISP's Name= ChangeMe
Encapsulation= rfc1483
Multiplexing= LLC-based
VPI #= 8
VCI #= 35
Service Name= N/A
My Login= N/A
My Password=N/A
Single User Account= Yes
IP Address Assignment= STATIC
IP Address=0.0.0.0
ENET ENCAP Gateway= N/A
Menu 11.1 - Remote Node Profile
Rem Node Name= ChangeMe
Active= Yes
Encapsulation=RFC1483
Incoming:
Rem Login= N/A
Rem Password=N/A
Outgoing:
My Login=N/A
My Password=N/A
Authen= N/A
Route= NONE
Bridge= YES
Edit PPP Options=N/A
Rem IP Addr=N/A
Edit IP/IPX/Bridge= N/A
Session Options:
Edit Filter Sets= No
PPPoE Idle Timeout(sec)=N/A
PPPoE Service Name=N/A
Schedule sets=N/A
Menu 11.2 - Remote Node Profile
Rem Node Name=Rn2
Active= Yes
Incoming:
Rem Login= N/A
Rem Password=N/A
Outgoing:
My Login=N/A
My Password=N/A
Authen= N/A
Route= NONE
Bridge= YES
Rem IP Addr=N/A
Session Options:
Schedule sets=N/A
这样改了以后,电脑(xp系统)不能进行拨号。我又到menu11.3进行更改
Rem Node Name= Rn3
Active= Yes
Incoming:
Rem Login= N/A
Rem Password=N/A
Outgoing:
My Login=N/A
My Password=N/A
Authen= N/A
Route= NONE
Bridge= YES
Rem IP Addr=N/A
Session Options:
Schedule sets=N/A
好了,问题出来了!在这里提示:VPI# and CVI# is duplicated with another remote node!!!从而无法更改!我晕!!!!
哪位DX指点我到底哪里做的不对?
附带说明:我这里如果用路由上网的话,vpi#和vci#用的是0、100,否则是8、35没有错。
[/img]
